What the heck is that noise?
jlrsteno
NC
98 4.0 TJ Sport
U-joint?
Any help is much appreciated.
Too many moving parts on that side to be able to narrow it down with a 4 second video. I suggest to get a grease gun and get underneath and start hitting all of the fittings.
Thanks for the replies.
Update: Hitting all the grease points didn't work.
Turned out to be control arms and bushings.
Reactions: glowell222
Be sure the front shaft is ok regardless-
Everyone on this forum with the TJ that has not had the front stock shaft rebuilt or serviced needs to consider it-
Grease dries out-
Failing front shafts are catastrophic. They take out the transfer case usually.
