I know It’s a flat head ford, but I can’t get specific about the year.
Well, the hood could use some help.
You have an early flathead based on the water outlet. Count the studs in the head. It's probably a 21 stud. Post some better pictures of everything and we can narrow it down. Do you have a rear end for it?
Also, please don't scrap it. There's some traditional hot rodder in need out there that will give you something for it.
The fenders still look mostly rot free, and the engine, while it’s probably seized, is complete.
Found this on the property we’re cleaning up.
I know It’s a flat head ford, but I can’t get specific about the year. It’s pretty complete though. Obviously, the rubber is gone, but the carb is still there, plugs and wires are there, magneto is there, etc.
Interestingly enough, the back half of this sedan is on property as well, in a different spot. Looks like they removed the sedan buddy for storage, as there is a spool of barbed wire inside it and it’s “parked” next to the old cow barn.
That's a '37 Ford. Looking at the top of the grille, it's flat, which says it's a '37. The '38 shares the same headlight trim rings, but the grill is a different shape up at the top. The protruding headlight bezel was an aftermarket conversion for sealed beam headlights. The original headlight lens and trim was much sleeker. Someone added the conversion kit later.
'37s with the sealed beam conversions...
...and '37s with the sleeker original (non-sealed beam) headlights...
That's a '37 Ford... The protruding headlight bezel was an aftermarket conversion for sealed beam headlights.
Based on what Wiki had to say, that flattie is a '36 or earlier 221 cid. As you noted, the water outlets (actually, the water pumps) are located at the front of the heads.
As that car is a '37, I would venture a guess that it was an early production '37, and used a "leftover" '36 engine (seems plausible), or it was simply an engine swap that someone did somewhere in its lifetime to keep it on the road (which seems very likely to me).
