thats the condensation drain from your a/c- heater core box. it should drain like that if you run the a/c . also will drip antifreeze if your heater core has a leak. clear water is fine, antifreeze is bad !
it also is the drain for the box located under the vents, it fine and normal. take a hose and pour water in the vents fwd of your windshield and water will pour out of that tube
So I put a paper towel to it and it does look clear. However we are in MA so she definitely wasn’t using the air conditioner last night when driving. If anything she would have been using the heater. This leak just started And wasn’t there during the summer. I doubt she ever used the air conditioner this summer since she had it stripped down.
If she ran the windshield defogger, that runs the AC to pull the moisture out of the cab and will produce condensate for that drain.
The heater core gets flow whether the heater is on or not so for a heater core to start leaking right when the heating season starts would be pure coincidence.
I'm sitting here and 2nd guessing myself, don't both the HVAC box and cowl both drain out that hose ?
Most likely draining from keeping it on defrost since it uses the AC to dry out the cabin. Its been quite wet here in the Northeast lately with all the rain and I've used my defrost more lately than I have in the past.
However, I would still keep an eye out on the coolant and check the drain often especially when not using the defrost.
So would a clogged cowl drain affect it. I actually had that thought too since I pulled a bunch of leaves out of her air filter box. that thing is probably full. I’m grabbing my tools from work in a bit so I can change her idler pully and belt so I might as well check that too.
The cowl drain and the drain tub for the condensation tray in the bottom of the HVAC box under the dash are not connected by anything the factory did.
Also, all cars do it.Would this be the reason it’s suddenly causing a puddle under car when it didnt do before. I did check with her.
