Hey everyone,
I am on the verge of replacing my frame; finally addressing the largest flaw of my Jeep.
What are some maintenance items I should perform while I'm in there? This can include those only possible while the frame is off or more easily completed under the circumstances.
Model Specs:
2000 Jeep Wrangler Sport 4.0L 5MT (NVG3550)
Mileage: ~164K
3.07 axles dana 30/35, No lift
Recent Maintenance items:
Radiator, Hoses, Water Pump, Fan Clutch, Transfer case Replacement, Valve Cover Gasket, clutch throwout bearing, clutch master cylinder
Below is a list of maintenance items I have identified (some previously completed, as noted):
Model Specs:
Mileage: ~164K
- Brake Lines (pre-formed stainless steel) - Completed
- Motor Mounts
- Transmission Mount
- Fuel tank skid mounting hardware (rusty)
- Oil Pan (slight rust build up from scrape)
- Transmission gearbox flush+fill
- Fuel lines (rusty)
- Exhaust System, Front-to-Back (cracked manifold + rusted to hell OEM cat back)
- frame-to-body mounts
- Engine Cleaning (Grimey from Valve Cover Leak)
