Chudlet's First TJ
Got my ARB air compressor assigned to and Auxbeam button in the cab so now it runs when I push the button or flip the switch under the hood.
Got the wiring harness for the locker solenoids put together and just need to mount the manifold and locker solenoids on the little shelf where the antilock breaks setup would normally go.
Finally made the appointment to have the gears and lockers installed next week. Still kind of on the fence about going to 4.56 or 4.88 gears.
Also added some Amazon grab handles (Wild Boar) to the windshield. They are not bad, appear to be solid aluminum bars and the welds are not fantastic, but they are ok.
$650 an axle.. half of what I paid here in the NE.
I have an NV3550 with 33's. I did 4.56 and it is spot on perfect for a daily driver with occasional rocky fire road use. Zero regrets. Had I thought 35's were in my future, which they are not, I would have done 4.88
Reactions: Wildman and chudlet
Spent most of the weekend working on my daughter's car, replacing belts, headlight assemblies and a few screws that refused to exit the vehicle without the use of a drill bit and tap. But I did get to squeeze in a little time with the Jeep and finished up the wiring for the locker solenoids. Got the ARB manifold mounted on the antilock tray. Had to order a few bits and pieces of hoses, connectors and such to put everything together. Not much to show other than a pic of the Auxbeam pannel with a few extra stickers added. Wish there was a "winch" sticker in the kit but closest thing was "power" so I guess that will do.
Pretty sure I have a winch sticker.. I'll check.
Reactions: chudlet
I'd have to look at my stickers but I thought it had a winch one.
This set does.
https://www.amazon.com/Auxbeam-120Pcs-Switch-Sticker-Vehicle/dp/B0BG1K1FTK/?tag=wranglerorg-20
Oh very cool. if someone has one they don't mind donating to the cause, that would be great, if not, Amazon here I come.
I have the new larger version so I don't know if my stickers will fit or not. But I'll measure one and let you know it's size.
To catch up on current happenings. I got the Jeep back from Bill Johnsons Differentials late last week and have started breaking the gears in. He would have had it done the next day but some of the parts I provided had some issues. The front R&P were for a Dana 30, just not my Dana 30. Apparently, there were different pinion shaft lengths over the years and model of Dana 30. So new front R&P was ordered along with a new bearing kit. Then putting it all together it was discovered that the ARB I Facebook sourced, was indeed for a Dana 30 BUT was for 30 spline axles not 27 splines, so to make it work I had to upgrade to 30 spline shafts. I guess if I have to screw up my parts I might as well end up with a stronger setup anyway?
All said and done, I ended up with 4.88 gears, F&R ARB air lockers, and upgraded 30 spline Dana 30 for $2300. A little more than I wanted to spend, but the axles are ready for 35s whenever I am, I guess.
Well, I did not get any wrenching time over the weekend like I hoped, but I did get some last night. Change the oil, added a Stahlbus oil drain QD and installed this Facebook find.
Hoping to get my caster dialed in a bit better and air lines run to the lockers in the very near future.
Not really a picture post because yesterday's Jeep Garage Therapy Session was more about cleaning up loose ends and adjustments. So just for documentation purposes:
1. Got the lockers plumbed with air, tested and found and fixed the obvious leaks. 5 min, pressure test in the garage and no cycling of the air compressor. Time to test them on the trail.
2. Installed a 12Oclock Labs Speedo fixer. Plug and play easy. Wires are long enough that I routed the controller up by the brake booster and zip tied it off. Easy Cheesy. Now the speedo is dead on with GPS.
3. Added about 2.4* castor with 2 full rotations of the lower control arms, got DL vibrations at 60 MPH, dialed them back 1/2 a rotation and still have a little vibration at 70 MPH, so next weekend when I get back from a work trip I'll dial them back another 1/4 turn and see if that gets rid of the last of the vibration. Steering is much more predictable now. Jeep seems to want to stay in the lane without feeling too light.
4. Discovered the front DL was contacting the Tcase skid when I drooped the front axle to plumb the locker air tubing, so I modified the skid a bit so no touchy at full axle droop.
5. Finally found left and right sided US Flag stickers on Amazon so they got added to the Jeep.
Time to add some weight and protection to the Jeep. Low and behold, CavFab sliders.
Following those that have gone before me, I welded in a spacer for the rear torque boxes, but only needed a single 1/4" spacer just a hair shorter than the spacer CavFab had on their. I also made some backing plates out of 1/8" sheet steel, which are not really worthy of pics. Lesson learned: what I did not need to do was drill a hole in it. Turns out the hole in the added spacer lines up pretty close to an OEM hole in the frame. So spacer good for spreading the load, but not good for securing the slider.
Second lesson learned: folks said the front came up a bit short of the front wheel well. No one ever showed a pic of these with OEM fenders so no one really new how short they are. Well now we know they are 4.5" - 5" short on OEM fenders.
I did ask CavFab twice to leave them long for full coverage and the only answer I got back was "we are not taking custom orders at this time". So there you go. I think I am going to grab some scrap 3/16" plate from work and see if I can weld on extensions to cover the last 5" as it is going to be some time before I can afford super cool aftermarket rock crawling fenders. Here is where it sits as of now. I still have to drill and tap the bottom hole for the fender flair. Should have that done tonight or tomorrow.
Added a couple things to the Jeep lately. Picked up a Radioddity GRMS radio bundle. Came with the DB20-G to mount in the cab and a handheld to take with while spotting or winching or to loan out, whatever. It is nice because it comes with a C-Lighter power adapter so easy take it out of the rig if you want to or you can cut that off and hard wire it in. I have only had it for a week so still figuring out exactly what I want to do. I'll probably splice it in behind the dash with a quick disconnect so I can still use the C-Lighter to charge phones or other USB peripherals. I got the basic magnetic antenna but it worked out really well this weekend. I stuck it to a flat piece of scrap metal and set it in the back.
I drove to Montana to go wheeling this weekend and my (some would say unhealthy) addiction to Market Place / Craigslist turned up a kid wanting to sell his set of five 35x12.5x15 BFG KM3s for $1400 so he could downsize to 33s. Tires on the road are about 80% and the spare is brand new. Hit him up to see if he was interested in my 33x12.5x15s in pretty good shape. To sum up we traded straigh across his 35s for my 33s. My spare was just about bald so I gave him $350 so he could by a new spare. A little ahead of schedule, but not really a deal I could pass up and I was already there to go wheeling.
This to that ->
And while I was over there, I came down a little too hard on a log and made my front drive line not so cylindrical anymore. Guess Ill be talking to Tom/Shawn Woods driveshafts in the morning.
  • Wow
Reactions: MikekiM
View attachment 528226View attachment 528227
This to that ->
View attachment 528228 View attachment 528229
Murl's driveline service. Broadway & Sycamore.
Yeah that is what another buddy just told me. I'll head down there tomorrow. Thanks for the tip, good confirmation.
Reactions: All 4 Wheelin'
