Designing filler for auxiliary tank
andyj
adelaide
Hi TJers,
I've got a Long Ranger tank that came with abysmally bad hardware to connect it. So bad actually that it is impossible to fill the tanks up to capacity. I'm now planning to get a dual filler neck done to solve that problem. The original filler neck has a 1 inch pipe down to the main tank and I'll add the same for the auxiliary tank. The auxiliary tank has a 34mm connection (the tank manufacturer calls it a high flow solution). I need to make some kind of "adapter" from 25mm to 34mm on the way down to that tank. So, now it comes:
Is it better to have a short "bottleneck" closer to the filler neck
fuel in > ——========================== > tank
or could I use a one inch hose down to the tank and have the adapter there (long "bottleneck")
fuel in > —————————————-==== > tank
It's a bit of a question of how liquids behave in such a situation.
Having a long, small diameter hose all the way down would make it easier to route it through. What do you think?
I'm American and bigger is better...I'd run the larger 34mm hose size down...ought to be able to get or have someone turn something out on a lathe to suit.
All of that depends on whether or not you can get fuel safe 25mm and 34 mm hose...and if 34 even fits.
I'm no fluid mechanical engineer...but as long as the tank is vented...it ought to work.
If you can open that up to match, that would be the best option.
If that's not possible, then I'd for sure run the largest diameter inlet tube down to as close to the tank as you can get it, THEN convert to the smaller diameter.
If you could taper it like a cone, that would be awesome, but probably not really worth the effort.
Venting will be an absolute requirement given that you want to fill the tank at a reasonable rate using a somewhat restricted inlet.
The reason I mention this is because here in CA we have these snorkle-type shrouds and back pressure check-valves around the gas nozzles to help capture fumes and prevent over-filling, leaks, etc. Regardless of public opinion of them, they are here to stay and will probably become standard everywhere.
You can rarely set the auto-fill because the venting has to be just right to avoid triggering the back pressure shutoff function.
Anyway, if there is restriction close to the filler (as opposed to being closer to the tank), then the amount of fuel that can be dispensed before triggering the back-pressure valve in the pump nozzle will be very limited and you would never be able to set the auto-fill because the valve would continuously get reset.
If you ever plan to fill up in a location that uses these types of filler nozzles, you'll curse any restriction that makes it slower than it already is!
I'd find a shop that can weld a bung on there and go BIG! ;)
Going big is a bit of a problem because there is not much room at the top of the original filler neck to connect something of that size. I didn't consider the one inch size of the original tube too narrow, it's what's there for the main tank and it seems to work. However the hose to the main tank is just 10cm long. I don't know if the length of the hose has an effect, though.
Hi TJers,
This is he type of adapter you could source or build with a tubing expander. Then weld it to the filler neck. Or just cut the filler neck off at the transition and weld one a 34 mm pipe ( 1 3/8” ) . Another way would be to go to a u- pull junkyard and look for a filler neck that would work or could be made to work.
https://www.bearriverconverters.sto...MIwMHtp_u5hAMVcButBh0dFQ6pEAQYCiABEgJEqPD_BwE
I guess I re-design the thing. I could extend the 60mm funnel down 150mm and weld on the 34mm and 25mm tubes. That could prevent that splash back that causes the nozzle to switch off all the time. My TJ has always been difficult to fill up. It's weird. I had a 2001 TJ before and never any problems. Maybe the filler neck got changed for the 2003 model, who knows.
I decided to go to the top and weld on a long 60mm tube with two short 29mm tubes for the tanks. That should prevent at least the splashback.
I'm more into timber to be honest. I started with a model of the area around the filler neck.
That's the first part, the little funnel at the end:
It took ages to make it but was fun to work with a new material :o))
It looked easier that I thought. The thread for the lid is made from plastic and glued in. How would I weld that? Thank god I'm happily married and my wifey gave me some goo and stain remover to solve the problem. Wtf it did work!
@andyj How did this turn out in the end? I love that you mocked up the jeep corner out of Plywood!
I have the LRA aux TJ sitting on a pallet in my shop waiting to get installed... Interested in hearing advice you have if any on the install.
Thanks,
Josh
It did work, I can fill up the tanks. However, it takes some patience. The hose to the aux tank runs horizontally over the rear axle and that's a slow process. A separate filler neck would be better, but there is nowhere room for the hose.
Back
Top
