Shop press "embiggened pusher"
hear
Can't type
Lifetime Supporting Member
Prosper, TX
I have the HF 12 ton shop press I'm using to remove my carrier bearings with the help of a bearing splitter (got the idea off youtube). I got some 1" thick steel plate and made new arbors out of them, drilling holes in them to allow for the bearing splitter & carrier to hang below the shelf. The problem is that even with the shelf at the highest spot, the push rod can't reach the carrier. a deep 32mm socket would probably do the trick (if I had one), but it seems like having some various sized "dies" and like 6" of steel roundstock would solve this in general.
Is there something like this out there or a diy type thing? I mean, it has to be somewhat common to not have the exact right sized die available, and/or the rod not being long enough for certain things.
The other alternative is to drill another set of holes higher up, but that feels like it could be a royal pain.
I have a set of aluminum seal/race drivers but something tells me putting them under 12 tons is not a good recipe.
I have two shop presses - a 12T and a 20T air-over-hydraulic. Both are Harbor Freight with mods I've done to make them more useful. I used to have access to a 50T with an electric hydraulic pump (when I worked at Polaris 20 years ago). I miss the 50T for sure! I will tell you that you need three things to use a shop press efficiently: 1) a bunch of solid rods of different sizes and tubing of different sizes (sockets work very well), 2) a healthy dose of creativity, and 3) an even healthier dose of safety awareness.
Oh, yeah, one of these universal press supports is helpful, too:
It's the only thing I've found to replace wheel bearings easily on my Subaru.
Nice fixture but it doesn't come cheap at $470
https://www.amazon.com/dp/B00X1JXYKK?tag=wranglerorg-20
Here's an alternative that's easier on the pocket book at $105
https://www.amazon.com/ABN-Universal-Drill-Press-Support/dp/B079P5499R/?tag=wranglerorg-20
  • Wow
Reactions: hear
What I'm missing is all the spare steel lying around. I’m also thinking a ball joint press kit would probably do the trick. I was just hoping there was a "press kit" sort of thing that has a bunch of stuff like what you'd commonly need.
Reactions: freedom_in_4low
There are very limited press kits available, but in my experience, there is no "commonly" about it. It seems no matter how many press doo-dads I collect, I always need something I don't have. That's why having a huge drawer of sockets is good - not only do you have a socket for every occasion, but you also have a good selection of press doo-dads!
Reactions: Rickyd and Squatch
If you have a steel yard close by, they usually have containers of remnant's of solid round stock material as well as pipe & steel plate.
I have a 60 ton press that needs rebuilt, the cross beams are 10”x3/8” c channel and is bent and I found a replacement piece of c channel so now for a media blast and a new pump
Reactions: John Cooper and sab
If you have the bandwidth, a thread on HF 20T press upgrades would be wonderful. I've watched some of the youtube vids, but I generally trust the advice I get here much more than youtube.
I know the air over hydraulic cylinder is an easy bolt in. Keeping it from racking is a big concern of mine...and I haven't really invested any time in prevention. I have some steel set aside at work to make new arbor plates from...another project. I also have a 3D printed pressure release knob.
I'll see if I can start a thread. A lot of the stuff I did is from the Internet idea pool, so I can't take credit for most of the ideas. I've:
  • Added Swag Offroad Release Knob (I like steel! It's not 3D printed. I bought one for my 10T HF press and my engine hoist, too.)
  • Added Swag Offroad Bed Plates
  • Added Swag Offroad Press Brake
  • Added Harbor Freight Air-over-hydraulic Cylinder (yes, it's a bolt-in mod)
  • Designed and Fabricated a Hand Crank to Raise and Lower the Bed (was too heavy with the Swag Bed Plates and Brake)
  • Added Nylon Set Screws for a "Straighter Push"
"Racking"? I think my last mod noted above addresses that, but I'm not 100% sure what you mean by that.
Twisting, torquing, etc. I’ve noticed the frame twist or move a bit when I get a good load on mine.
Link that thread here, please!
Reactions: Danarch
