I was looking for a way to replenish potable water in the wild so to speak. I researched the commercial offerings and found them deficient for various reasons and built my own. The 2 main commercial offerings are the Clearsource Nomad and the GuzzleH2O Stream products. I like the Nomad up to a point but have some issues with the design and components chosen. The GuzzleH2O just seems poorly designed all around and the marketing materials are misleading.
My initial design goals were to produce potable water in a single pass through the system from any reasonable surface water source to include desert cow tanks and western rivers. I wanted 2 GPM flow rate but had to settle for 1 GPM to accommodate the requirements for 1 of the components I used.
I ended up with 3 10" filter elements, a 12V pump, and a 12V LED UV purification component. I just had samples from before and after treatment tested for E. Coli/Total Coliform. The raw sample tested positive as expected and the treated sample tested clean!
Current filtration consists of a strainer on the pump intake, 30 micron, 10 micron, and 0.5 micron carbon block 10" elements followed by the UV component. Power comes from any 12V battery.
I'm going to get a more thorough post-treatment test done on a different source, probably some river water.
