So I recently bought a '00 Sport (4.0, 5spd). It has a 4" suspension lift and running 33's, stock Dana 30/35. Previous owner said it has 3.73 gears, however after comparing what they said about other things I've seen/worked on since taking ownership, I have my doubts. So through some digging here I found grimmjepper.com and entered my parameters. If I place the ratio at 3.73, I'm typically just shy of the proper RPM/Speed that GJ spits out. So I tried 3.07 and its even further off (my RPM' are higher). I'm utilizing a GPS app for my speed. So I decided to jack the passenger side rear wheel up, leaving the driver side rear wheel on the ground, and give the passenger wheel two full revolutions while counting driveshaft revolutions. I get just shy of 3 full revolutions. So now I'm confused as all get out. Will someone verify I have entered the correct parameters into GJ, shown below. If I have, WTF is going on? I guess my only way to verify the actual gear ratio, at this point, is pull the covers and count? Thanks.
