Had a leaking rear axle seal on the driver side. Pulled the shafts, replaced the fluid, bearings, retainer, seal, etc with Timken bearings and seals. They pressed on fine and without issue. No knicks, burrs, cuts remained when getting the old ones off.
Sealed fine for about two weeks. Now the driver side is leaking again. Vent is not clogged. No heavy offroading lately so I don't suspect any tube damage. Didn't see any either. Retainer plate torqued to spec and I used thread lock. Any ideas?
04 Rubicon. Dana 44.
