You all realize the OP was made in 2020 and they have not been back since April 2021?
Never underestimate the ability of a new member to necro a thread to answer a question that wasn't even asked.
Ironically, we would be better off if the search were disabled for new members. Just force them into starting a new thread.
Wait...you mean newbies actually use any of the search functions? Instead of asking questions that were asked and answered a few zillion times?
Or even scroll down a few posts...
BS, mines a 97 and haven't had any issues finding parts, but then she never breaks down either?
Damn bro, that thing is F'n CLEAN!!!!!!
97-98 ac controls are the only part I've run into that is hard to get. Though the later style hvac can be adapted.(yes i know this is a 4 year old thread)
You got a link to a writeup? I heard this was extremely difficult as the vacuum plugs aren't even the same.
Anybody know where I can get a PCM ?![]()
Greetings from Finland. I have a 1997 TJ and would like to 'upgrade' my climate control panel to the knob type (currently I have the slide type). Can anyone advise me if it is a simple plug and play or what is needed to make the change. Would like to know the additional parts I would need and is this very complicated? My TJ does not have AC (obviously due to my location). Many thanks
- Jeep tj Finland
- Forum: TJ General Discussion
Below I will give you detail on how to change your 97-98 sliding knobs to turn style for your heating and cooling. I will tell you what I did; other years might work, but I will only tell you what WILL work. I have a 97 Sport, 4.0L manual 5spd.
I decided to do this because I disliked the sliding style, and I had all sorts of trouble with my blend doors not working properly. I also wanted to replace my heater core and evaporator. With that being said I spent $200 on a salvage heater assembly, instrument cluster wiring harness, vaccum line harness, and the turn style switches (all from a...
- TJDave
Aha! I seen this before and to be honest, I completely glossed over it cause it seemed involved with harness splicing. Wondering if I should just cab swap to a 2005 with everything already in it.![]()
That sounds like a LOT more work IMO... But that also depends on the current shape of your tub & if you can get a 1999 or newer tub for cheap that has everything in it too.
Cab and drivetrain swap if you don't want to be splicing wires
