Oil pressure gauge is reading low
Zacc
United States
My cousin just bought my 97 wrangler.
150k miles
The guy he bought it from said that when he’d run regular 5w-30 or 10w-30 in it, the oil pressure gauge was saying it was a little low so he began running straight 30 weight oil, he told him it could be the sensor being bad but he doesn’t know so he just ran thicker oil, any ideas whether he should continue doing the same thing or what should he do? He also said that he’s been doing that for a few years now and has never had a problem.
My '97 did that at warm idle when I bought it at about 150K also. Mech gauge pressure was never less than 12 PSI. No rod knock or other obvious issue. My solution was a new stroker :)
Reactions: SouthernTJ2000
I'm on the same page!
Stuff happens so my stroker I had planned ain't happening in 3 months.....
Still gonna happen though!
Reactions: Woodrow
I was freaking out when i first built my stroker and had the gauge drop/dash beep until i tried a real gauge. New mopar sender didn't solve it.
I really need to figure out the issue in the circuit,it's still unnerving when it happens
Reactions: Woodrow
150k miles
As suggested for peace of mind pull the sensor and temp a mechanical gage to the 1/8" port near the distributor. FYI if your relying on an aftermarket oil pressure sensor don't, it's a waste of time since they are commonly crap in a box.
Golen uses a std volume Melling pump in their strokers. My dash gauge (the same gauge and sender that showed 0 and triggered warning light with the stock motor) shows 40 PSI at warm idle and nearly 60 with cruise RPM. What does the mechanical gauge show for yours?
I used a standard melling pump as well. My dash reads 30-40 psi cold or hot, but will drop to zero occasionally . I've been too lazy to chase the wires.
I don't remember what the mechanical gauge read anymore,i think it was around 20psi hot. Next time it decides to beep at me i want to get another reading now that it has close to 30k miles on it.
Reactions: Woodrow
Interestingly, on sustained steep descents in Moab a couple of weeks ago, I did get 0 on the gauge and the light. Though startling, I wasn't too concerned about that, but it does suggest the gauge and pump are working as they should.
I wouldn't think you'd get low pressure if the rpms were up on compression braking. I'm assuming it is using resistance to feed the gauge and a bad wire or connector is putting it out of range?
I thought it was actually oil starvation because the inclines are so steep that all the oil in the low part of the pan where the sump is, moves forward.
not that I’m aware of. Maybe I should be more concerned 🤷‍♂️
The stock pan has a baffle at the front of the sump to keep oil in it. I guess you could get a mechanical gauge teed in and try to recreate the low pressure situation?
Maybe ask golen if their pans have it?
No, I believe you were the only one.
However, a couple years ago @NashvilleTJ and I both took our jeeps over the fall on Steelbender. I went first and check gauges came on and I think an alarm went off but once leveled out it was fine. I believe Jeff had the same issue when he did it. That's considerably steeper than the descents where you had your issue.
I haven’t had the pan off that motor. Maybe the pick up is more toward the back or higher off the bottom of the pan than normal. I should call Golen and see if they have any insight. But it certainly seemed like that’s what it was doing as it went back to normal as soon as we were more level.
Reactions: Apparition
