Hmmmm… didn’t know that.. I keep mine on recycle all the time..
It works best on the early models without the tailgate vent. I can't tell a difference on the 06.
When doors off need to remove the fuse for lights. Keep that in mind.
I have a Trektop NX and half doors on year round. I like a soft top versatility. View attachment 547796
I was actually wondering. What's the tailgate vent for? My 03 has it but the 01 doesn't.
My wild ass guess is that if you put a soft top on your 03 that it will sound pretty much exactly like your 01 with the soft top.
I may be wrong, but I did stay at a Holiday Inn last night.
Hard tops used to have the vents on the left and right sides. They removed the vents from the tops and moved it to the tailgates. The vents let the air out when you close the doors or use the heat/AC with a hard top.
Not necessary on a flexible, leaky soft top.
Well, there you go!
pretty much all vehicles have a vent, usually it's hidden behind the bumper cover. I'm sure the HVAC fan has to do with it. Jeep originally only thought hard tops needed them and they were in the hard top. At some point they moved them to the gate.
We had both tops on a 04 , first a soft then a hard , to be honest HVAC and sound weren't my issue with the soft top . But try commuting on dirt road in the Rockies and you can't ever see out the side quarter or rear windows. The UV eats the Bestop plastic windows fast. The try to open or close the rear zipper in the winter , If you get it open you won't close it again till summer. We got a hardtop and never looked back.
all good points. All my soft tops have lived in insulated garages that never really got below 40 and no UV unless being driven. I wouldn't even consider running a soft top on one that was kept outdoors.
Never had any issues with any soft tops or the zippers. Outside all year. Maybe the 98% humidity helps preserve the tops in the summer.
p.s. My top was over 12 years old when I replaced it 3 years ago. I keep the zippers clean and lubed, so they work smooth in all weather conditions.
