Been pondering for a while on how to winch backwards and I finally got around to trying something.
Rear bumper fairlead is a recovery ring, trimmed to get a flat side, u-bolt to attach to the bumper.
I made the front fairlead from a piece of softwood firewood, shaped to fit against the stinger gusset. A single lag screw through the gusset keeps it from sliding around. This is just a prototype, and I assume it will wear fairly quickly.
Couple rub spots I'm watching: back of front fender well,
And this box profile at the front of the rear wheel well.
A few light hammer taps to make sure the edge is rounded over and you don't want the rope getting cut on sharp edges.
Initial results are promising. I have to be careful to make sure the rope follows the intended path. When slack it can foul in a couple spots: at the front roller fairlead it can drop below the side roller, and it can get below the front body mount horn when leaning passenger. Once snug it holds true.
