The only way the column loses its ground is if the mounting screws are not there or have magically become isolated where they are no longer connected to the tub. That and it would take about 8.5 seconds to clamp a wire on the column and stick the other end under any of several ground screws in the immediate area. The TJ is a body ground set up if that wasn't obvious yet. Pop a speaker grill off, yep there is a series of grounds under a screw into the dash frame. Pop the cluster out, yep, there is a ground going to a screw behind it. Body ground, pretty hard to separate the column from the body without some effort and break the ground circuit.
