No ground to steering column
dglazeii
Marianna, FL
I am having issues with my horn button not working. If I connect the wire in the steering column to a know ground, the horn works. Is there a ground wire that is used to connect the steering column to ground and where would it be located? Thanks, Doyle
Wiring diagrams are in section 8w.
There is no wire for ground. The FSM states to check the continuity between the metal steering column jacket and a good ground. If there is no continuity the steering column mounting nuts should be checked for proper installation.
Reactions: macleanflood
If my horn did not work when I pushed on the air bag cover where the horn symbol is, the first thing I would check is the clock spring.
The wire connected to the clock spring works. The issue is that the steering column is not connected to a ground. Need to find where it would connect and check it.
The only way the column loses its ground is if the mounting screws are not there or have magically become isolated where they are no longer connected to the tub. That and it would take about 8.5 seconds to clamp a wire on the column and stick the other end under any of several ground screws in the immediate area. The TJ is a body ground set up if that wasn't obvious yet. Pop a speaker grill off, yep there is a series of grounds under a screw into the dash frame. Pop the cluster out, yep, there is a ground going to a screw behind it. Body ground, pretty hard to separate the column from the body without some effort and break the ground circuit.
That is my thought but it is the case. The steering wheel is not connected to gound and don't understand why.
You have taken a test light, hooked the clip to power 12V+ and touched the column inside the area behind the knee blocker with the probe to verify that?
Next to your battery is a big ground cable that runs to the firewall...is that present? Might want to clean the battery terminals and that ground location.
Yes, that is how I know that I do not have a ground to it.
I just pulled the knee blocker off and checked. The 2 bolts at the tilt are isolated from the column via the plastic bushings. The next pair of studs at the firewall are not isolated at all. If you put either a continuity checker or powered up test light, the two studs are grounded to any part of the aluminum column.
