This morning I started early on the cross-member design before going to my meeting in Austin. I took advantage of the trip to "the big City" to pick up some DOM tubing for the cross-member (more on that in a minute.) After dinner, I made my way back out to the shop and put the last three nutserts in the frame. Then I came back to the house to finish the cross-member design.
The design I have in mind was inspired by this design @mrblaine posted here a few years back. Of course, it wouldn't be a sab design unless I over-complicated it! I'll take the 1" x 3" x .120" rectangular tubing that I have and drill four small holes all the way through from top to bottom with a pattern that matches the OEM rubber mount's studs. Then, I'll drill the top holes to .375" diameter (or so, haven't decided) and the bottom holes will be cut to 1" diameter from the bottom side to the bottom of the top wall using an annular cutter. Next, I'll cut the tubing down a plane halfway between the top and bottom surfaces and bevel the edges. Then, I'll cut four pieces of the 1" x .120" wall DOM tubing I bought today to go into the 1" holes. With the .760" I.D., a 13mm socket will fit inside.
I'll then weld it in this order:
Tomorrow, I'll start building it. Stay tuned!
(skip to Post #318 for the continuation of the cross member build)
- Fixture and weld the tops of the tubes to the inside of the top tubing section (that's why I'm cutting the rectangular tubing in half - to have access to weld)
- Fixture the top and bottom pieces back together and weld the bottom side of the tubes
- With it still in the fixture, weld the two halves back together
