Mildly Out of Hand 02 Sahara Build
Hate to steal your line, but is someone going “Full retard!!!!!”?
Got a killer deal worked out for some jk44s. My plan is to push the front forward as much as I can and install the front coilovers. I think I can end up at 101” wb with the gas tank under the jeep still. Then all it needs is an atlas or Rubi t case and I think that would be about it.
If I learned anything from your thread I’d keep you in suspense. But no not tons
Well DAMNATION that isn't very nice.... Ya'll need to stop this crap...
Glad you didn't make us wait too long...
I may have missed it, but how much rear stretch do you have and what tank are you running (or going to run for 101” WB)?
Genright Comp 20 I ended up with about 6" of rear stretch but have plenty of room 1-2" behind it with the TJ 44. I plan on maxing it out in the rear with the Jk axles and pushing the front as far forward as I can without relocating the steering box.
Reactions: Wildman and Tob
Look forward to seeing this next progress in your build. I hope you can find some wheels similar to what you have now. It really makes your rig stand out.
Reactions: Tob and 02GreenTJ
1552 makes a wheel called analog thats an alloy wheel with the old steely look in a jk bolt pattern. A few sprays of rustoleum almond and I'd be back in business. Pretty painful to drop that kind of coin and not have beadlocks tho.
Really. That’s interesting you got 6” with that tank and still have 1-2” more. IIRC you didn’t move the arch. You frenched in your uppers and moved your upper shock mount. What kind of travel are you getting in the rear?
Reactions: 02GreenTJ
Really. That’s interesting you got 6” with that tank and still have 1-2” more. IIRC you didn’t move the arch. You drenched in your uppers and moved your upper shock mount. What kind of travel are you getting in the rear?
The coilovers helped with the non arch moving. I like the aesthetic looks of moving the arch but it wasn't necessary for my purposes. Right now its at 7.5" up 4.5" down which isn't ideal. When I originally set it up it was 6" up 6" on essentially 2" of lift. I ended up raising it when I did the front mid arm with spring preload.
I planned on getting back to 50/50 bias using different eyelets (like the ones shown) but figured I may as well wait for the axle swap rather than make new bump pads etc. I'm going to play with spring rates and tuning once I have it sitting at it's final ride height and wheelbase.
Edit: I think genright also told me you could get 7" in the rear with a dana 44 and that tank. I can send pictures of diff clearance if you'd like.
Reactions: JMT and Wildman
I will also say it wheels and drives pretty darn good (for my standards) with the uptravel bias. I haven't really noticed any negative characteristics that have made me want to immediately change it on or off road.
Get the internal beadlocks later on.
View attachment 567986I planned on getting back to 50/50 bias using different eyelets (like the ones shown) but figured I may as well wait for the axle swap rather than make new bump pads etc. I'm going to play with spring rates and tuning once I have it sitting at it's final ride height and wheelbase.
Hmm…interested in your coil over setup. I’ve looked into the GR Alien tank to stretch. I think it’s about 10” rear stretch.
