I’m looking to upgrade the speakers in my TJ. I’m deciding between Alpine Type Rs and Polk MM1s. I’m looking for solid sound with clear bass at higher volumes. I do not want to rattle the glass, I only want clear audio at higher volumes, topless on the highway sort of thing. I have upgraded speakers in there now, but when I have the volume on higher levels, the bass is distorted....even with the bass turned down low. The Polk’s have a higher sensitivity, but I’m thinking the Alpine’s will handle deeper tones better. Both are similar in price at $200 a pair.
Adding an amp is an option I’m considering,but adding a subwoofer is not. Thanks in advance for any input.
As someone else mentioned, do you have a sub in your center console? That adds a small punch but you cannot turn it up too loud since it will rattle. But a Kicker pro comp 6.75" is a great plug and play option.
Others have installed hideaway powered subwoofers but you stuff them under a seat. If you want a stealth build, that option is not for you.
You didn't mention what year Jeep you have, or the sound system, but you can add a 6.5" to the speaker pod and 5.25 in the dash pod.
An amplifier will be what you need though. It will help big time!
I am about to commence another audio upgrade and will be selling off some parts that go well in the Jeep, especially an amplifier, the Kenwood KAC 3004 marine amp. Small, compact, 4 channels and 75 watts per channel. Fits under the steering column and really powers the 4 speakers.
As for your two speaker choices, I would lean towards Polk, not Alpine. You could do better as well, for a couple bucks more check out Focal Performance or Morel Tempo Ultra.
Also, sensitivity is the rating for converting power into sound, not quality or clarity of such sound, and many manufacturers make unrealistic claims about their rarings. So don't let sensitivity be the end all measure when making a decision.
