Hello all I'm sorry for having to ask for wiring help but I have read many threads but could not find the solution to my problem. I have completed a chassis swap on my '97 Tj and it won't start. It ran before the swap but now there isn't a proper ground at the fuel pump connector.I have 12 volts at the plug and the fuel pump runs with alternate 12v source, all the relays and fuses are good. the Jeep runs on starting fluid.My problem is I can't quite decipher the wiring schematic, I'm trying to trace the ground wire circuit and it looks like the ground wire goes to a S132 connection then to a G105 connection then an S130 connection and on to PCM cavity A32. Am I to assume I should have continuity between all these points with the key on or off? What are the connecting points S132, G105 and S130, are these ground points on the engine block and body? As you can tell wiring is not my strong point. thanks in advance for any help, Gary
