Hello,
I am currently in the process of a complete frame off restoration of a 1998 TJ 4.0L automatic and I am loving every step! I have gotten down to the point where the tub is off, frame is out and engine/trans are off the frame as well! I started working with the idea to do safety caps to fix the rusted frame but ended up finding out my frame was WAY to far gone to safely do this. So I jumped onto FB Marketplace and scored a ZERO RUST 2005 TJ frame as a complete roller. The seller included the 2005 steering box with the longer shaft so I can just connect my steering column right to it. He also left me the transmission skid plate. This is where I have a question! Since I have a 2005 skid plate for the transmission do I need to move anything over or do anything to make my 1998 transmission mount to the 2005 skid plate? I obviously have both the 1998 and the 2005 skid plate available but I'd really like to keep the 2005 one since it's cleaner. I do need to order new transmission and motor mounts and they look the same for both a 1998 and 2005 so I'm just slightly confused. I have seen people talk about the need to drill different holes but I wasn't sure if it was when they used the older one instead. Thank you for all of the help in advance!
