Duner’s 99 Sahara Rebuild
That also could be the way to go. How does this fair to magni-coating? Any down sides to galvanizing?
Haha I don't actually know, but I know it's done to prevent rust and isn't goopy like fluid film/woolwax stuff. Helpful I know... I figured you'd know more about rust prevention than me in the desert
Reactions: Stretch97
Picked up the frame from sandblasting, looks clean!
Repaired a small section on the bottom of the frame. Was quoted $1600 to get caps done, but there was no reason to do that. Would have cut out metal that had more than enough life left. Should have tacked it higher so it would have been flush with the original bottom, oh well
Installed rancho shocks along with OME springs for the 2.5” lift. Installed the 4.0 today as well. We decided since the yellow tub is in better shape we are going to swap that on, so we pulled that off its frame earlier this week. Will have to remove the evap system and current dash to swap over the correct one. Getting closer!
Starting to button up the wiring. Anyone know what these extra rear connectors are for? My only guess is a security system to shut off the fuel.
Was able to modify / combine existing trans mounting brackets to get the 32RH to mount to a 03 skid plate. Not sure why I assumed the skid plate mounting to the frame/ trans was the same for all TJ’s. Either way glad I got it work out!
Reactions: Rickyd and lBasket
