Hey all.
I recently purchased a 2001 TJ 2.5l and was told it needed a fuel pump as it would randomly studder under load.
I replaced the fuel pump and both O2 sensors (NTK) last weekend. I decided to drive it Tuesday morning and it ran completely fine, parked for about an hour and then ran completely fine again to the next destination. No studder, idled fine, etc.
After work I went out to crank it and it immediately started spitting and studdering at idle and died. It did that multiple times so I ran it up to about 2k rpm's and the studdering stopped unless it went down to idle. I drove it home while keeping the rpm's up and luckily made it.
I performed a fuel pressure test and it jumps right up to 40-45lbs and leaks down if I don't crank it. Once I crank it, it stays around 40-50lbs at idle or when giving gas. At idle it just dies again.
Any help would be much appreciated.
