Broken ground strap?
Noname
Canada
I just found this messed broken ground strap on my hood. What problems would something like this cause? Or what is associated to it? Makes me wonder if this could be something that would cause a problem with the ground wire to my p0153 oxygen sensor issue?
It electrically bonds the hood to the rest of the body. I don’t think it’s the culprit for any oxygen sensor issues.
It doesn’t interfere with the electrical current to the ground points and sensors that travel to the pcm?
Google what the hood ground strap does. Then look at a the wiring diagram in the service manual to realize your o2 sensor ground points aren’t directly connected to the hood.
Ya …lol it states that they are there to provide a reliable ground. P0153 is associated with an oxygen sensor which has 2 signal, heater and ground circuits.
Once you learn where the o2 sensor ground points are and where the major ground points are for the vehicle, you won't consider the hood as the source of your o2 sensor ground problem.
Reactions: Tob
Yes, lol g0105 ground point is located on the chassis and considered a main ground point for the 02 sensors, sir. The strap is considered part of the “electrical” system and creates a strong current for sensors, etc. If the strap doesn’t exist what problem will arise, explain.
  • Face Palm
Reactions: Obi-Wan
Most likely nothing will happen with that strap missing. It's mainly there for RFI suppression (preventing electrical interference caused by the collapsing magnetic fields occurring with every spark plug ignition.) There's no component that requires the hood for its ground path.
Your post is a perfect example of why AI "ain't ready for prime-time":
1. The hood, without the ground strap, is not electrically isolated due to incidental points of contact like the hinges and the latch. 2. Current is not flowing through the hood because nothing uses the hood as a ground path (barring installation of some accessory that does.) 3. There's no ground strap to the chassis, so saying that the hood strap is required to ensure "that the hood and other parts of the vehicle are at the same electrical potential as the chassis" is silly. If the chassis has no ground strap, the hood strap can't ensure that.
Seriously? 12V of potential isn't enough to create a shock hazard. That's why you can touch battery positive with one hand and battery negative with the other and live to tell everyone how tough you are. :ROFLMAO:
Again, no stock component relies on the hood for a ground path and "crucial" is utterly ridiculous. However, as I said, the ground strap helps contain RFI sources to the engine compartment, so some radio noise (especially on AM radio channels) is possible with a missing ground strap. FM is generally not affected by that RFI, though.
What a vague statement that means nothing if you parse it out. How does the ground strap prevent corrosion? How does it prevent damage to the vehicle's electrical components and wiring? Hint: it does neither.
I guess if you have a high concentration of stray gasoline vapors and something causing the hood to become charged (usually rubbing something on it), this might help prevent a fire caused by electrostatic discharge, but those conditions would be a freak combination of weirdness.
Look, I'd definitely run a ground strap. However, without one, you're unlikely to notice any issues, especially an issue with an O2 sensor. In fact, from the picture you posted, that ground strap is likely working well enough because it doesn't look like it's disconnected completely; rather, it looks like it broke and was tied together, which is likely good enough. By the way, to tell if it's good enough, just use an ohmmeter with one probe on each end of the ground strap. All is well if the resistance is close to zero (a few tenths of an ohm).
Reactions: Tob
It is simply there to stop static electricity that builds from wind rushing across the hood from causing noise in your radio and false readings in other electronics in your Jeep.
Easy answer to your situation. Replace it. If you don’t have the braided cable use any bare copper wire for a temporary fix. Parts store should have plenty in stock.
Fix the easy stuff and go to the next.
