My 06 jeep wrangler straight 6 has the following issues:
has been running rough and throwing up the engine code p2302 (ignition coil circuit 1). Replaced the ignition coil and ran ok then started misfiring again and throwing up same code. any advice?
2). The fuel pump fuse randomly blows. I checked the wires and no kinks or anything, dropped the tank and checked the pump seems to be ok. I decided to run brand new wire to the cable running from fuse box. Seems to have solved the issue for time being, question I have is other than fuel pump and kink in wire what else could cause it to blow?
