gasiorv
I'm a new world samurai, and a redneck nonetheless
This is on my Ford E350 van but brake systems are brake systems and general knowledge about brakes should apply so I figured I would ask here after not being able to find anything on the Econoline pages.
I have bled the piss out of the brakes on my van. With engine off and no boost, the pedal is at the top and hard (doesn't budge with 215lbs standing on it). When I fire it up and boost comes into play and I depress the pedal it travels about 1/2 way with a loud air whooshing sound (atmosphere air entering booster, not vacuum leak) and then gets tight. It doesn't fade at all past 1/2 way it is tight and you can't pump it up. it is not like there is air in system, the brakes are there and feel good once you make up that travel. I bled and bled and even bled the abs module with scanner multiple times.
With the tight pedal with engine off and with the pedal not fading once it gets tight at the 1/2 way point, and the fact that it doesn't pump up when at the 1/2 way point it does not seem like an issue with air in system or with swelling lines, etc... it seems like an actuator rod length and brake pedal travel before rod hits master cylinder issue; however, when engine is off the pedal is hard at the very top so I don't think I need to adjust engagement length of rod.
Is there is anything in the booster that could possibly add travel? It is a solid rod between pedal and master correct? Or is there two rods (one on atmospheric side and one on vacuum side) and if so what is in between them? Could that fail when vacuum is applied and allow travel?
Hopefully the above makes sense. I just bought this van so not sure how the pedal felt before, I just know I don't like how it feels with it going approx 1/2 way down before engaging and I have made sure caliper slides were free, rubber hoses look good, installed brake pads, and bled, and bled, and bled. It just doesn't feel like air in the system. So I am considering booster, but the booster is actually working (minus the travel concern the booster is adding boost)
Any input or help is appreciated and I have thick skin so feel free to rip on me if I am missing something obvious. I just want to get this brake pedal feeling right.
