does anyone have a link to the 2" spacers for sale?
I ordered mine from Lug nut guys https://lugnutguys.com/?country=US
Too little backspacing and the scrub radius is too greatly impacted causing poor handling and accelerated wear on the ball joints.
This is why mine has 4" backspacing on 35x12.5" tires
Yea if it was easier, we would see it here more often. Most just accept the spacers.
Look on facebook marketplace like 200 sets
my amazon-fu is failing me, not sure how to search for 2 different sizes. I either get 5x4.5 or 5x5 but not the adapters.
I always use the Titan Wheel Accessories adapters/spacers.my amazon-fu is failing me, not sure how to search for 2 different sizes. I either get 5x4.5 or 5x5 but not the adapters.
I cringe every time I read or hear about spacer use.
I would have been your buyer if I didn't jump on @Renegade TJ 's stuff.I posted these for the Moab trip and nobody was interested but I'll leave a link here if someone wants them shoot me a PM and we'll figure out a price w/shipping.
Is it true you have to grind/cut down the wheel studs with 1.25" spacers? I brought my caliper out when I installed the 1.5" spacers, but I forgot to use it...
PTSD. Post-Traumatic Spacer Disorder.My guess is a traumatic spacer experience as a young child...
Those shafts do exist. 300ish per side. 5 on 4.5, 5 on 5, and 5 on 5.5 bolt circles. Your exhibited propensity to be both cheap and stubborn would normally cause me to highly recommend you fetch these up for a bit of karmic entertainment and then I realize that you are not that bad, so I'll warn you off.I'm scared to death to run spacers. I had them at one point and the inner lugs (?) loosened on me and I about lost the wheel while driving. I used the red locktite that came with them, but clearly that worked well.
I'm on the verge of regearing to 4.56 & 35's, but finding rims that fit is a challenge (mostly because I'm cheap and I need to find them on marketplace). I assume nobody makes a dana 44 axle shaft with 5x5" bolt pattern in a TJ length??
I am only aware of 2 locking hub kit bolt circles. 5 on 4.5 and 5 on 5.5. The JK folks have to swap to the 5.5 circle if they convert. Or at least that's all I've been able to find.Unless you go to a locking hub kit in the front, nobody makes a front unit bearing (to my knowledge) for the TJ with a different bolt pattern.
Another thing I didn't think to check is the size of the pockets between the bolt holes in the wheels. if the small open nuts that come with the spacers fit into those, it might not matter if they protrude a little. Eyeballing mine at 1.5", it's a close call whether they'd stick out or not anyway. I'm sure someone here knows for sure.
Blue would have thrown off the color scheme I got going, anyway. RC spacers are adonized light-ish red, so now I'm up to like five or six different shades of red... body, hood, doors, floor, hinges, and now spacers.
