The all metal National Throwout bearing has been recommended here a few times so when I replaced the NV3550 transmission with a NIB Novak AX15 in Q4-2024, I did the National instead of the plastic piece included in the LUK clutch kit.
Started to hear some clicking when the clutch was pressed and released. Thought it was the clutch MC & slave so ordered a new one of those direct from Mopar and while I waited for it to come in, the TO bear failed and took the (possible good) clutch slave with it.
Replacing the National TO bearing with a Mopar unit.
FWIW, this was the third or fourth clutch MC+Slave I installed in the past 12 months. First two were Duralast from the local auto parts store. The next was a LUK kit.
Can't say whether there is issue with the National TO bearings, but I won't be using one again.
