NSG370 feels a little rough
adventureboss
Phoenix, Arizona
So I replaced my six speed NSG370 in my TJ about 50k miles ago with a rebuilt High Impact after my friend unfortunately blew my original. I've been doing transmission fluid flushes every 20k-25k miles with Redline MTL. This gearbox normally doesn't ever really feel smooth. It has a notch when cold going into second gear, and it feels rather gritty when going into third at times. In 4low, when I shift from second to third it would straight up grind. Other times, it goes in just fine. Sometimes I have a hard time getting it into first gear, especially when cold. I can't remember if it's always been like this.
Weirdly enough, if I'm shifting full throttle at redline, it feels very smooth. During normal driving, it sometimes feels like crap. I would think it'd be the opposite especially because I'm sure I have some synchro wear at 50k miles on a rebuilt transmission. It's making me anxious and I'm wondering if I'm unfortunately going to be due for another transmission soon. I don't understand though because I don't drive my TJ like a racecar, and I've kept up with fluid changes and all. Then again, I've also heard these transmissions have never really shifted well and they aren't supposed to be smooth.
Thoughts?
  • Sad
Thoughts?
There are no known reputable rebuilders of the NSG370. Advanced Adapters sells an adapter for swapping in an AX-15. It’s a much better transmission, and they are still making them brand new.
Reactions: ColoJeep
Eagle Transmission in Cedar Park, TX did a great job.
I got all the parts, sourced on what I knew it would need, was going to do it.
Then took it to them, and works excellent.
The B&M shifter makes it a lot better, that’s just me.
Kind of curious, you’re changing your Transmission Gear Oil every 25k miles?
That seems like a lot to me…I don’t think it would hurt it, just seems fairly often
That’s good news for @adventureboss and @astjp2. See reputable rebuilder of NSG370 above.
I was being sarcastic.....I think any good transmission shop can do this....if they source good parts. I took that out of the equation....I got all the parts, LOTS of threads on the NSG370.....A LOT of them on this forum.
I find it better to go to Google, type TJ FORUM NSG370 "whatever you want to add" and there are pages of information.
www.nsg370.com is also a place for some information.
I think now there is actually an internal shift fork that uses brass and not plastic connectors? I wish that was there when I had it rebuilt.
The 2009+ JK internals for rebuild, fixed a lot of the issues. I believe the design of putting so much into the shifter/shift tower, spring detente wise etc....which is why they're so dam expensive, has something to do with it.
You will never hear me and nsg in a good way. I despise them, shitty Mercedes design that should have stayed in a car!
25k miles? I can’t even get 25 miles
  • Sad
Reactions: lBasket and JMT
I would disagree about any shop doing a good job…
