Hooking up your O/D isn't hard.
You need a momentary connection to a ground. The easiest way is to use a relay with a momentary switch hooked up to it. The switch energizes the coil in the relay and you use that to connect the O/D wire to a ground. I have a push button switch on my center console but you could use the dash switch if you wanted to. I'd have to look at a 05-06 schematic to see how it's connected but it shouldn't be a big deal one way or the other.
