Agar426
I’ll share my current experience and maybe @Wildman and @NashvilleTJ will chime in soon.
My situation is somewhat unusual. I drive my LJ a lot. It’s almost a daily driver for me but I also use it to tow a 3200# travel trailer and then unhook from it and trail ride and sightsee or adventure wherever we go. So it’s a Swiss Army knife type rig.
When I did my Hemi swap I used a stock replacement water pump, thermostat and a custom CG&J radiator with a flex-a-lite black magic electric fan for TJs. I used the same hoses as @Daubie3. I do have Air conditioning and a transmission cooler and power steering cooler in my grill with a warn 9.5 ctis winch in front of everything. My radiator is a down flow style with a built in oil cooler. The CG&J radiator is a really nice and well made piece. BUT immediately I had overheating issues. You’ll read about them in this thread. With the Efan i would overheat at highway speeds. Pretty much anything above 45-50 and it would hit 245-250 degrees within 10 miles. So I reluctantly swapped the Efan for the stock jeep 4.0 fan and shroud with some modifications to the shroud to fit the Hemi inlet and outlet on the radiator. I did not overheat at 55mph but it would overheat at idle and if towing. So I swapped to the explorer fan and severe duty clutch. I hated it. It was very loud and you could just feel it suck the power out of the engine. Now I could tow at 60-65 before overheating but it still overheated at idle, in traffic, and when moving slow offroad. I tried a standard clutch in place of the severe duty with little change in the noise. The I found a similar fan design that was on a Jeep WJ I think. I tried the Dorman replacement for it (620-082) and matching standard duty clutch. It is significantly quieter and less drag on the engine. But still overheated under the same circumstances. Then I tried the severe duty clutch for it (Hayden 2791). And only slightly more noise but still overheated. I found a Flowcooler water pump for the truck Hemi. That’s where I’m currently at.
Great info, thank you! How is the current setup working?
