AOSJ
1st on flat ground from a stop, 2nd if I'm already rolling slightly or pointing downhill.
As for when to shift, it all depends on conditions. Cruising on flat ground at a consistent low speed? 1,500 RPM is plenty. Merging onto the freeway on a short ramp? Floor it and shift at redline. Basically you use as much gear as you need for the situation.
Don't be afraid to skip gears too, especially with the 6-speed. Here in the Pittsburgh region, people tend to accelerate a lot harder than they do in other regions. (Probably a learned behavior from the hills and oddball road designs.) So it's not unusual for me to run it up to 3,500-4,000 in 2nd or 3rd and then skip a gear (or even two) into 4th or 5th to cruise.
If I'm cruising along at 1,800 RPM in 6th gear and then get an opportunity to pass someone, I'll shift straight from 6 to 3 and then run it right up to redline before going to 4th. The 6 to 3 downshift is very easy to do smoothly, just simply double the RPM before dropping the clutch and flooring it.
holy shit dude, you really wind it up that much? I would never run mine that hard
