Lol that actually doesn't seem bad mostly small parts.
I'd guess about $450-550 in parts total but I haven't priced it all out yet.
The transmission mount bracket & isolator may or may not be needed but again won't know until I've got the transmission under the rig & looking at how to mount it.
The transmission pan is cracked on this transmission, which isn't the end of the world as I wanted to change the filter anyhow & obviously all new fluid too. On the car version the filter is part of the pan where the truck pan the filter is separate but either version is about $175-200. Where a PPE aftermarket pan with a drain plug & temp sensor bung is $305 so I know which way I'm going there.
The NEXT part is that the ZF/8HP transmission take a "special" ATF (of course) & is about $25 a quart & it'll take about 12 quarts if it's completely drained and then adding the size of cooler & lines. It a Mopar ONLY fluid. I'm not sure what the fluid life is but this tranmission doesn't have a dipstick. You fill it thru a fill plug on the side of the transmission. And there is a WHOLE process you have to follow when doing it. One part is that you have to LEVEL the transmission (not the vehicle) so if it's got a slight slope to is towards the rear you'd have to jack up the back to make it level. And you add the initial amount and then start it and it has to be running & above a certain temp to get the final fill.
One other thing I've found out about is that they like this transmission to run between 175-200*
