Transmission leaning
There have been alot of issues with the 3 core radiators failing sooner than you'd expect. If you don't already have it consider the Koyorad A2102 which is available on Rock Auto, priced well (~$110) and seems built better than Mopar. I picked one up recently to keep on hand. I installed a replacent Mopar about 8 years ago (they're no longer available) so was able to look them over side by side, measure the core etc. The tubes are a few mm wider front to back. Koyorad isn't well known in the Jeep world, but is considered the gold standard for many imports.
I already have a radiator from extreme terrain. It's all on hold now. I went to change the motor mounts and the driverside mounting bracket to the engine is cracked, a bolt was broken off in the block and a chunk of the block is missing. Now I need to do a major frame check to see if it's worth putting a reman engine in it.
  • Face Palm
Reactions: Weasellee
