my wife has a 99 TJ 4.0L automatic trans. it began turning over but not starting a while back after being driven and warmed up good. let it set a while and it will eventually start up and she can drive away and no issue. I researched a bit and determined the CPS was going bad so I bought the best one i could from napa. problem seemed to go away but started doing it again. finally did it to me at O'Reillys one day so I just bought another CPS and changed it. fired up and I drove off. continued to have same issue and today she started it and as she was pulling out of driveway it died and wouldn't start. I took air breather off and sprayed starter fluid in it. still wouldn't start. pulled a plug wire and stuck a new plug in it to check for spark and it has spark. also I've put a fuel pump in it just because. im at a loss.
