Doing a frame swap for a 97 4.0 to a TDK frame without mounting holes and I got rid of my frame a while back.. took lots of pictures but didn’t measure that. The fsm provides frame dimensions but no mounting locations.
Can anyone give me rough dimensions on the mounting locations for the two exhaust brackets on the passenger side frame rails?
The mount just to the rear of the muffler on the exhaust pipe I believe is supposed to be close to the rear sway bar frame mount on the inside frame rail with two bolts. The rear most exhaust bracket is on the outside frame rail and is also mounted by two bolts.
With the new stock exhaust I can get things line up pretty well and clear the rear track bar, and passenger shock boot. Had to bend the exhaust tube hangers a bit. Just hoping to get it as close to stock as possible.
A good measurement point between both frames should be the sway bar link mount.
Thanks!!
Thanks!!
