What is so special about Mopar parts?
I have no idea what you are doing but I've done many cooling systems with 100% Mopar parts without a single failure and we've yet to see a failed plastic impeller. I use Mopar because I have a 100% success rate with 100's of their parts. If I didn't, I wouldn't use them.
I bought one of @mrblaine Jeeps. My jaw dropped when I saw it even had Mopar wiper blades. I didn't even know that was a thing. I've had it over two years and those blades are still good. It was parked in the garage until recently though.
The only part I am not impressed with is the OEM windshield. 🙃
I have a 2006 TJ Jeep with never replaced windscreen. The little metal part for rear view mirror came loose. I took it to our closest reputable windscreen dealer to refit whatever they use. I were told they will only work on glass they supplied or original manufacturer glass. I know it was never replaced and it has the chrysler badge and name SAFEGUARD DOT-22 GG-M54. 43800146. Some "clever" expert I presume that do parts at JEEP SA advised that Jeep only uses Mopar windscreens. On closer inspection on Mopar's website it clearly specifies Jeeps from 2007 to present has Mopar windscreens installed. It is not a big issue as I could refit the little item myself but I wish to cross swords with those that embarrassed me in their shop. Unfortunately South Africa are full of d-witts in jobs they should not occupy. Thanks for your assistance.
Like any MFG'er id say their parts are engineered and fit better than anything aftermarket. That was pre "made in china" where much if not all of mopar parts comes from now from my purchases. I always use one of the many OEM dealers as well. There is just to many bootleg parts on the likes of scamazon which is not new.
Reactions: ColoJeep
I've noticed the OEM MOPAR parts are getting quite expensive out there and it seems like whenever someone posts a thread as to which aftermarket brand is best, EVERYONE tells them they'd be doing the job several times over unless they spend 4x on a MOPAR part. Honestly, I don't get it. Maybe it's just me, but I've had just as bad luck with MOPAR parts as I have with aftermarket brands. For example, the previous owner had Pep boys replace the water pump at some point. I saw this in the records, got a little sketched out, and pulled it out and replaced it with a MOPAR pump. They appeared to be of similar build quality with the pep boys pump having a metal impeller instead of plastic. That water pump lasted 60k miles and was still good, just pulled it because of paranoia.
The new MOPAR pump as I was recommended to replace it with on here lasted 900 miles before the plastic impeller flew apart and it started leaking from the weep hole. Loved changing it out when it was 115 outside in Phoenix that summer haha. My MOPAR thermostat? Went bad too in less than 50k miles. Replaced it with a Robert Shaw and that's been great. That's why when it came time to replace the radiator too, I was told to spend $400 on an OEM MOPAR radiator but considering my other experiences with MOPAR parts, I instead spent $80 on a CSF and called it good. So far, it's been working great for the past 60k miles as well. So really, I don't understand. When I'm looking for what part to buy on these sites, I just see "MOPAR", blanket statement, as 100% always the answer.
Maybe I've just been unlucky, but just why? I would understand going MOPAR for something like a sensor that maybe has finer tolerances, but for something as basic as a water pump or a radiator, or even an idler pulley, does it really make sense to spend a few times the price as a reputable aftermarket brand?
Non MORPAR idler pulley here ........
