Need low profile taillights and Savvy has no ETA in sight
Thanks, I'll order all of it when I see it's available. Meanwhile can anyone tell me which flasher I should order for my 2000, the EP27 or the Novita LM470? I'd rather not do the trace cut on my original, and I'm not exactly on a budget so the best is what I want. Will be leaving the fronts incandescent.
When I installed the LEDs for the sidemarkers, front directionals and LED tail lights; I had a buzzing of the emergency flasher relay while trying to use the flashers which caused the instrument cluster directional indicators to pulse. I traced out wiring looking for loose, oxidized or chafed wires/connections and inspected the bulb receptacles along with trying the LM470; none of that resolved the problem until I used the relay that a forum member suggested.
The Off Road ONLY Relay GCD-TJ0106 from Amazon resolved my buzzing relay and pulsing indicators.
https://www.amazon.com/GCD-2001-2006-Wrangler-Flasher-Relay/dp/B07LC4DMS1/?tag=wranglerorg-20
In the meantime, we've tried that GCD flasher several times when it was the only one that Gerald sent out with the Savvy lights and it was terrible so I have no idea what works other than trial and error. I'll check to see if I still have any but if I do, they can be had for the cost of shipping because I'll never sell or use another one.
The BMB tail lights look like the best option, and I would certainly go with those and wish I did instead of the Quadratec ones I went with a few years before the BMB tail lights came out. The QT ones are fine brightness-wise, but ever since installing them my Jeep has this habit of blinking all of the lights (both tails and top brake light) when using turn signals. It is even more common if I have a trailer attached with trailer wiring. I've replaced the flasher relay and two turn signal stalk switches thinking it was that. Wiring is all good and grounds are spotless. Didn't have this issue pre-LED tail lights.
