Ring and pinion
Cidamli7
Cyprus
Hello everyone. I recently upgraded my tires to 35-inch, and now I’m planning to change my ring and pinion ratio from 3.73 to 4.56. First of all, I would like to hear your thoughts about the brand of the ring and pinion set I currently have. They are svl dana spicer...
Also, if there is a brand that you would definitely recommend, I would appreciate your suggestions. Thank you in advance.
The Spicer gears you have are the (SVL) Spicer Value Line. If you already own them, why not run them? Are they new or used? Are you doing the gear install yourself or are you paying somebody?
Reactions: macleanflood
Hello everyone. I recently upgraded my tires to 35-inch, and now I’m planning to change my ring and pinion ratio from 3.73 to 4.56. First of all, I would like to hear your thoughts about the brand of the ring and pinion set I currently have. They are svl dana spicer...View attachment 672864Also, if there is a brand that you would definitely recommend, I would appreciate your suggestions. Thank you in advance.
What transmission do you have? I have an AX 15 5 speed and wish I had 4.88s with my 35s
I have 35s with an ax15 and 4.88s. It's pretty good but I would like a lower t case. Ive ridden in an LJ on 35s with a 32rh and 4.88s. He really needed 5.13s+. Downhills were way too fast for me.
