I am currently frame-swapping my whole 2001 Jeep TJ 4.0. I’m about to pull the motor out , and I was planning to turbo the motor when putting it back together onto the new frame. From what I’ve seen, you can run that much boost without head studs and a stronger head gasket. The engine has 89,000 miles on it, and nothing has been done to it before. I’m just trying to get others’ thoughts on this and see if I should upgrade the head studs and gasket, or just leave it as is while it’s out of the car.
