Floor mat / liner comparison and review
Rockymountainhigh5
Idaho
I have been using the Rugged Ridge liners front and rear for about 3 years. Previous owner bed-lined the tub, I also have Bedrug carpet on top of that. At the time I purchased the mats they were recommended in several posts in this forum, and had generally positive reviews elsewhere. The rears have performed fine, and so I'm keeping them for now. Within the first few months the logo fell off of the driver side in the front, leaving two small holes in the mat. That hasn't proven to be overly problematic, other than a bit annoying. They generally fit well, as show here:
The primary issue I have is the bowing along the transmission tunnel (passenger side is exactly the same but mirrored). The location being directly behind the gas pedal is not ideal:
I thought maybe it just needed to loosen up with some heat. Sitting in the vehicle improved it slightly but not all the way. I've tried various strategies to straighten it out (left in the driveway, stacked stuff on it, blow dryer, heat gun, etc) all this has improved the condition but it only lasts a few weeks at most. If I was smart I would have just sent them back at the beginning. I recently decided I was tired of fighting with it. Narrowed my choice in replacements down to Weathertec and Husky. I've been generally happier with Husky Mats on other vehicles so I picked up a set of their Classic TJ Liners.
Comparison of coverage with Rugged Ridge:
Fitment on driver side:
The coverage is obviously a bit better, they fit tighter and have more of the spikes so they stay put better, and are easier to clean/wipe off due the more shallow diamond pattern. They are a bit less stiff and plasticky than the Weathtecs I've had in other vehicles, but not quite as thick and rubberized as the Rugged Ridges they replaced. Overall traction is adequate when they are dry and my feet don't slide around any more or less than the Rugged Ridges. Haven't had them wet yet - will update if that changes. Most importantly at this point - no gap:
The passenger side is pretty much the same as the driver. I can grab pictures if someone wants them. I'll update if something changes, but it seems to me if you're torn between Husky and Rugged Ridge liners, the Husky is the better product, especially considering the Rugged Ridges cost ~$40 more for the front set only.
I have WeatherTech over BedRug and some 1/4" Rubber Sheets. It's been good for several years now.
My son had those Rugged Ridge and they buckled right there in front of the gas pedal too. Very inconvenient and possibly dangerous.
I have the Barricade versions of the Rugged Ridge and have the same problems. They also don't seem to grip the BedRug carpet very well and slide pretty easily. May switch to the Husky eventually. I just cut up the Barricade cargo mat since it wouldn't fit well under my new rear seat. I cut it down to where I just have a small piece in the rear protecting the carpet.
Reactions: Rockymountainhigh5
I had the same set and although they work fine I just wish they where a bit softer and plyable, they're a bit too stiff for my liking. The Weathertech mats in my F150 are softer and more forgiving.
I will say about the WeatherTechs that I've had: they fit well and they were very durable.
That's interesting. My WeatherTech knowledge might be out of date. I had a set in an early 2000's F150 and a mid 2000's Toyota Matrix about 10 years ago, plus we had some in my wife's late 2000's Nissan Rogue up until she traded it in around 3 or 4 years ago. From what I remember all were stiffer than the Huskys I just installed, but probably not by a huge margin. Maybe older products, or me just misremembering. My main gripe with them was the lack of retention other than provisions for the factory clips. The nibs/spikes on the bottom of the Husky mats hold them in place a lot better than the WeatherTechs, especially on the passenger side where there are generally no clips. We had a lot of mat sliding with those, which was pretty annoying. I also have Huskys in my F250, different type of material than the Classics, but the experience is the same with little/no sliding or moving.
I agree the BedRug material seems slicker than factory carpet. The spikes on these Huskys are pretty aggressive. Currently no movement at all with driver or passenger side. No retention clip on either.
Reactions: bbaldwin237
WeatherTech changed their material about a year to year and a half ago. The older material would roll in on the top edges and the new material is supposed to be an improvement on that. I’ve got some of each, but not enough time to tell a difference.
PO had WT liners in the front and in the cargo area on mine. First thing I did when I got it home was throw them in the trash. The edges were warped and the material is too slick for my taste. I just got a pair of Walmart rubber mats with deep treads. Mud and snow are not an issue for me it’s the small rocks and sand that come off my boots and they just fall between the mat’s ridges. I just pull the mats and shake them out. My original carpet is still pristine. The TJ is vacuumed after every trip. I vacuum more than I wash the TJ.
I have a set of Bestop All Weather. I have zero complaints. I was never able to remedy the passenger side leak that runs down the fire wall so installed a bib that directs the water into the mat instead of under and into the carpet. A pool of water on the passenger side mat isn't uncommon, but the mat hold a lot of water. That said, a larger mat would be welcomed.
@Rockymountainhigh5, got a link?
This?
https://huskyliners.com/p/husky-liners-classic-style-floor-liners/
There are quite a few one star ratings and issue with the mat getting hung up on the clutch pedal is cited. If that were to happen once, they'd go in the garbage. Disappointed a little bit...
Yes those are the liners. I bought them from Quadratec because they were $80.99 last week. Looks like they've gone back up though: https://www.quadratec.com/products/14154_XX_PG.htm
There are 693 ratings, 2%, or about 14 are 1 star. Two of those were from the same guy claiming they "exceeded his expectations". None of them mention TJs specifically, but several mention other makes and models so these are clearly reviews across every Husky Classic Liner they sell. Now if the product line just sucked across the board that could be valuable information, but in matters of specific fit to a specific vehicle, I'm going to need a little bit more than "Mats hand (sic) up on clutch pedal. Not good." The only thing disappointing here is you equating the value between what I provided above, and the brain-dead bullshit from that 1 star review.
Not trying to white knight for Husky - I've got no skin in the game from any Jeep accessory manufacturer, I just want the stuff I buy to work. From what I'm seeing with these mats 3 days into ownership, based on the other vehicle specific floor liners that I've owned across brands and vehicles, it would taking a shocking and abnormal amount of curling to interfere with a clutch pedal. If the mats end up sucking, I'll update here.
Reactions: MikekiM
My '01 had Hysky mats in it when I got it and they worked ok except I thought they were kind of slippery. They eventually started to curl in at the edges and I replaced them with a set of Weathertech mats that my girlfriend got for me (Outstanding girlfriend!!!). I like the WT mats better than the Husky, they are made of more robust material, have not curled at all and are far less slippery. I gave my husky's to one of my friends and they are still in service in his TJ.
Reactions: JMT and bbaldwin237
All good.
My current mats don't suck. I've had them for four or five years and they still look great. I'm always open to spending money on the Jeep but if it's something I really don't need, it's easier to sway me to keep my cash in pocket.
I see them on Amazon.. maybe give those a try if only for the liberal return policy.
I've had Quadratec, Rugged Ridge, WeatherTech, and Husky liners. Every single one of them has rolled in on the driver side, by the transmission tunnel. My Husky ones are doing that now. The good news is, I can take a heat gun to them and reform them.
That ain't nothing a few small sheet metal screws and flat washers won't fix...... 🤫 🤫 🤣🤣
Reactions: Irun and ColoJeep
I'll bet that most of those with a drivers' side liner that is bowed out along the transmission tunnel either have removed or replaced their carpet, and the factory heat shield that is stuck to the side of the tunnel.
The liners are not "bad", they just get too hot.
We have the Bestop version in the TJ & they have worked well for abut 5 years now.
Reactions: John Cooper
