It has been a while since I last posted on here. I have looked at previous posts about the climate control only blowing out of the feet vents and some fixes that people have gotten, such as HVAC and engine bay vacuum leaks and broken actuators. However, I have checked all of my vacuum lines in the engine bay as well as my HVAC lines throughout the last 2 years or so whenever I get an error code; I haven't had an error code for vacuum or HVAC in over 8 months.
When I 3D printed that heat blend door actuator and installed it I also replaced the climate control (I believe it was this one: Amazon Climate Control). Before I was able to use all the settings of my climate control, minus the defroster due to the blend door actuator piece, but now I can only use the feet and the defroster vents. Both actuators behind the driver side dash are working and is changing the airflow, but the top one with the blue and yellow lines are only engaging the feet vents and stays on it unless the defroster is on.
Here is a video link of my actuator (too large of file to directly attach here): Video of Actuator
The video linked starts on the first right setting for defroster only, then each setting is applied until it is turned off. Could this be an issue with the new climate control I got from Amazon since the hands/face and feet vents were working before?
Thanks in advanced.
Thanks in advanced.
