So far my only area of question is C103 & C104 (14 pin) on the Jeep and C131 & C132 (10Pin) on the ZJ harness
After watching a few videos on all this.
I think I'll merge V8 stuff into the TJ harness.
So I just leave the C103 & C104 alone.
Does that sound about right?
Seen this, but I'm using a ZJ engine harness, and a TJ firewall harness and a RAM ECU
There are still wires that have to be spliced or added... But it's been too long now for me to remember... And I sold my Magnum harness a couple of months ago to another forum member so can't go look at it.
And in that list what doesn't match up between the GC & Ram plugs?
Looking at your post #3 I would think you need to blend the wires from the GC harness into the TJ harness...
https://wranglertjforum.com/threads/5-2-swap-questions.89881/post-1900331
no not last night.
Found the AI was basically what I already had. Mild differences but ones that look more like "Options" than requirements.
I am sorry, my nights have been busy. I will gather what I can and post it.
it would be neat if you could put all the information into AI and then it tell you what wires to blend.?
@Wildman
do you have a more detailed write up of the following?
Looks to be my last step
You need to add a pin to Pin # 13 on your C3 plug. Run the wire through a relay and connect the other end to ground. Then connect a momentary switch to the coil of the relay. To turn OD off hit the switch & to turn it back on hit the switch again. The OD controller wants to see ground momentarily to turn it on & off.
No that is about as detailed as I've got..
Technically you don't have to use a relay either. You just need a momentary switch. You're grounding the signal to the O/D solenoid inside the transmission.
It's just a quick connection to a ground that disengages or engages the ground.
I did add a light also on my 46RE.....
View: %5BURL%5Dhttps://youtube.com/shorts/2-8ArJqVrz4?si=FUZZSNvJsQLTyAZb[/URL]
