Fuel Pump Suggestions
Deep East TX LJ
Deep East Texas
I installed the Motobilt Fuel Cell in the bed of my ‘05 LJ. Everything went smoothly (I’ll post the details in my build thread soon).
However, I would have never guessed how loud the fuel pump whines. The brand is Detroit Axle, it’s brand new.
Does anyone know of a brand that is relatively quiet?
Have you put a few hours on the pump? I replaced mine with a Bosch unit and remember it being a bit noisy for the 1st couple of times I drove the Jeep. I don't know anything about the Detroit axle pumps. I used the Bosch 67756 in my 06 LJ and after the first few runs it has been silent and reliable.
Reactions: Deep East TX LJ
Only a few miles. I’ll run it some more and see if it settles down. Thank you.
Normally there are at least 2 layers of steel plus carpet between you and the pump , I'm not surprised it's louder than expected , it's inside your Jeep now .
Reactions: Daryl
Normally there are at least 2 layers of steel plus carpet between you and the pump , I'm not surprised it's louder than expected , it's inside you Jeep
How did you mount it? Using some vibration isolation mounts might help. Big on the might.
The fuel cell comes with a mounting bracket/ring. It’s as tight or tighter as the OEM fuel tank would be.
Right but the OEM tank is under the tub and the harmonics are certainly less noticeable.
Noise ultimately is vibration. A couple of cheap Amazon rubber isolation mounts might help.
I wasn't quite following earlier. I see where you're going with that. I will certainly give that a shot. Thank you Mac.
The Detroit Axle was $115 and I just bought a Delphi yesterday for $165 shipped. If that doesn't work, I guess I'll try Bosch next. Maybe the stuff I am buying is too cheap?
Delphi is what I'm running and have recommended to others. Except for one instance of installer error, out of 4 Delphi pumps (mine and 3 others in jeeps belonging to people I know) they've been flawless and trouble-free.
Walbro is an option that comes recommended for performance applications. Not sure how quiet they are. Bosch and Delphi are certainly worth looking at.
