Alright, PO765 code been popping up and throws it into Limp Mode. Reset it with my Innova handheld. Sets, reset, sets again. It eventually would be fine and drive. Tired of that plus I just need to fix it. Picture is what came from the trans cooler. Drained the radiator and it looks the same. So, leak inside the radiator and passing back and forth. It’s weird, the fluid doesn’t even look petroleum based. Any other ideas would be greatly appreciated.
Question is, can I delete the cooler for a little bit? I want to drain and flush the radiator, plug the cooler, and a simple run around circuit for the transmission until I can get a new radiator and plumb it back in. Caveats: in Mississippi(hot and humid), no heavy traffic, no A/C and no trailer pulling. It’s my DD. Really just trying to get it back on the road and check the transmission and get time to buy a good radiator and make sure I didn’t screw something up by resetting it.
Thanks for any help!
