Screw-type Tire Plug Review - Part 1
TJMexico
NW Mexico
A few weeks ago I asked about these plugs but nobody had ever used them. Somebody recommended that I try them and give a review, so I shall ... rather, I am.
Here is an image of the system from Amazon. The kits (there are many brands and presentations) average about a 4.5/5 star rating.
I was intrigued because you do not have to make the hole bigger to get the plug in as you would with string-type plugs. For a big hole that is not an issue, but when I have a tiny hole I hate making it bigger to patch it. Also, the overall process is quicker and easier. That would be a big plus on the road if, for example, you are in bad weather or in a hurry for any reason.
These are just a stubby little threaded screw with a rubbery coating. I'm not sure if the screw itself is metal or some kind of plastic. I'll have to see if I can strip one and let you all know in my Part 2 update in a couple of weeks. This package came with glue, though not all kits on Amazon had the glue.
I was able to plug the hole without taking the tire off of the vehicle.
This puncture was tiny. It shows up well in the video, but was hard to see with my old eyes. (I need some good work glasses.) Once I located it, though, I coated the plug with a bit of the glue and the plug screwed in easily. It seems to have plugged the leak. Of course, the proof is in if it holds after miles of service on rough roads. The puncture is right near the valve stem, so it'll be easy to keep track of. I'll watch it and check back in with part two in a couple of weeks.
If it does start to leak, I'll try to extricate the screw and put a string plug in its place. Or may just have to have it patched on the inside. I hope not, though. I have inserted many string plugs and never had them patched and they held forever.
Up to this point, it seems to have worked, but a couple of weeks down the road will tell us if it's worth the trouble.
Here is a video with a little bit of hands-on view.
View: https://www.youtube.com/watch?v=f11_oxarJcQ
I just bought a set with three sizes no glue. In the past I’ve had screws or nails in my tires that held air and just rode till the tires were worn out and needed replacing anyway, so when I first saw this I bought a set and decided if I ever needed it I’ve got a quick fix. I’m following along to see your results. Keep us posted!
As I said, I'll ride 'em out for a couple of trips and see. I'm not 100% convinced that they will last as long as string plugs, but I hope they do. Make sure you are on alert for this thread.
Reactions: TJ Jim
Do they install easier than normal plugs ?
Reactions: TJMexico
Yeah, it did install more easily. Much more easily.
Once I located the hole, I just juiced the screw up with some of the goop in the tube, put the tip in the puncture and turned it with with a phillips screwdriver. It went in like a wood screw in soft wood. No reaming out the hole, no shoving a threaded eyed awl through and yanking it back out. Much less effort and quite a bit less time than using string plugs.
My main reason for using it in this application, though, was, as I said, that the puncture was very small. A very thin piece of metal had made its way into the tire. To insert a string plug, I would have had to ream the hole out, making it several times larger than it originally was. With this screw-type plug, I was able to just let the hole keeps its tiny dimensions and fill it in with the screw plug.
My main concern is if it is going to stay forever. We are told that even string plugs should only be temporary and should be patched, but I have never patched a hole plugged with sticky string. I plan to carry a bottle of soapy water with me for a few weeks and check it every few days. If it begins to fail, I hope that I can unscrew it and put a plug in its place; otherwise, it'd have to be patched on the inside.
Gonna order a couple of sets after your next review, one will be for the Wife's mail car, the other for me. Heck might order 4 sets.
Reactions: TJ Jim
Post up which one's you ordered!
Reactions: ColoJeep and TJ Jim
Interested to see how these work out. When I first encountered them online, I was immediately skeptical. I've had great luck with traditional tire plugs, and thanks to my ol' lady and her constantly finding new and sometimes exotic items to get stuck in her tires, I've had more practice than many seasoned tire techs.
I'm of the "if it ain't broke, don't fix it" school of thought. But also happy to adopt ways to make things easier as long as I'm not sacrificing quality in the process. I'm just not sure how this makes things any easier.
Reactions: ColoJeep
Didn’t include any glue, and I’m curious if the glue is more a lubricant to ease installation? That stuff is slimy and slick till is flashes and dries. @TJMexico
Some of the sticky string plug kits come with glue, which I have never used and never had one leak, so you might be right about the lubrication aspect.
Reactions: ColoJeep
