Clutch master cylinder leaking at line fitting
dodj
Canada
So clutch wasn't doing what it is supposed to and checked under the hood. The clutch m/c was almost empty and you could tell it was leaking from the 90* fitting at the bottom of the plastic m/c. It appears to be held on by a cotter pin. Online looks like it should be a roll pin. Is that fitting serviceable or do you just buy a new m/c?
Thanks
Did you do the whole kit thing or is just the M/C the way to go?
Whole thing. It's pre bled so it's a quick bolt in.
Don't depress the plunger on the master until everything is bolted up. Otherwise the slug on the slave will shoot out.
Pay attention to the routing of plastic line and keep it away from the exhaust.
Reactions: dodj
Thanks Mac
Replacing it all.
Love the clutch part brand names on Amazon. Luk, Koomaha, shkalacar, labwork, etc....None sound like a reputable brand..lol
