Can I mix oil weights?
JMT
The Silver Fox 🦊
I was going to change my oil today so I bought a 5qt of 10w-30 thinking I had a quart or two at home. Turns out I don’t. But I have several quarts of 5w-30. Can I throw one in with the 5 10w-30’s? I live way out in the country and I’m not going back to town
Idk if mixing them would be a problem, I would guess not.. but it would alter the viscosity.. I do know in cold climates the Jeep can run 5w30
Absolutely ok and zero problem to mix them, all SAE motor oils are compatible with each other. You'll just end up with a 9W-30 by adding that quart of 5W-30 to 5 quarts of 10W-30. You can even mix conventional and synthetic motor oils together without issue.
Thanks guys! 20 minutes later, done. 9W-30, the Xact TJ specifications anyway, right!?
Reactions: Jerry Bransford
9.16W-30 to be exact. :D
It doesn't really work that way. One cannot simply average cold weather ratings because mixing does not change the cold weather rating in a linear fashion. However the math, while incorrect, does illustrate the concept that nothing bad will happen if one uses a quart or two that differs slightly from the manufacturer's recommended viscosity.
See, e.g., the discussion at: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4676074/1
FYI - The 2006 Jeep Wrangler Owners Manual specifies 5W-30 for the 2.4 engine and 10W-30 for the 4.0 engine. However, the 2006 Factory Service Manual does not differentiate between the 2.4 and 4.0 engines but instead recommends 5W-30 for both engines for ambient temperatures from -20*F up to 100*F and 10W-30 for both engines for ambient temperatures from 0*F to 100+*F..
Bottom line: Unless you live in an extreme climate you can use all 5W-30 or all 10W-30 or any combination of the two.
and your point is?
TJ2 said:
and your point is?
1. Averaging oil viscosity numbers does not provide an accurate or particularly meaningful result; and
2. In response to the original query and as stated above:
Between my girls, wife included and a few out dated vehicles in the driveway I change oil in 6 cars.
Sometimes I simply dump everything I have together to sneak in an oil change.....but never the TJ. Lol
Reactions: JMT and TJ2
As a follow up, has anyone had an oil filter that was cross-threaded out of the box? I had one today, tried several times to thread it and could never get it. So I grabbed another, fortunately I had one on hand, and it threaded perfectly. I’m going to call the company.
Please drink after you changed oil.
Reactions: johnny deeker
