It doesn't really work that way. One cannot simply average cold weather ratings because mixing does not change the cold weather rating in a linear fashion. However the math, while incorrect, does illustrate the concept that nothing bad will happen if one uses a quart or two that differs slightly from the manufacturer's recommended viscosity.
See, e.g., the discussion at:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4676074/1
FYI - The 2006 Jeep Wrangler Owners Manual specifies 5W-30 for the 2.4 engine and 10W-30 for the 4.0 engine. However, the 2006 Factory Service Manual does not differentiate between the 2.4 and 4.0 engines but instead recommends 5W-30 for both engines for ambient temperatures from -20*F up to 100*F and 10W-30 for both engines for ambient temperatures from 0*F to 100+*F..
Bottom line: Unless you live in an extreme climate you can use all 5W-30 or all 10W-30 or any combination of the two.
