Confusing on rear axle bearings
Spic
United Kingdom
I want to replace the rear axle bearings in my TJ 4.0l, it was built in 97, first registered in the UK in 2000, it has a Dana 44, Ive watched a few video's and they show the bearing's either on the shafts itself or in the end of the axle casing, is this just way they come out or do some fit directly to the axle itself and some to the shafts ? Is there any way of telling which I have before I strip it ?
You're good, those Timken axle bearings you ordered are the correct SET10 model.
Many thanks Jerry appreciate the reply . Can I also ask, do I have to open up the rear diff to release the shafts or is it all done on at the hub on the Dana 44 ?
All done at the hub on a 44.
Reactions: Spic
